CPU Cooler Problem
falcon1439
20
Hello guys, I'm a PC noob and I'm having trouble locating a suitable cooler. The diameter of the fan is 80mm and as you can see there isn't any more room. I'm having trouble locating a suitable cooler for it and I was wondering if you people could direct me in the right way. The computer is a Dell XPS8500 and the processor is an Intel i7-3770.
Link to image: http://imageshack.us/a/img36/4522/9oq2.jpg
Are you sure that it'll fit, it has to be exactly the same size as the stock one otherwise it won't fit. Thanks for your reply.
Good Speculation, you might find the coolers dimensions on their site? Ram wont be a problem as it is low profile. Also how far away is the case panel to the top of your current CPU? Those considerations e.g.
On amazon it says the product is 13 x 10 x 18 cm which I don't think would fit in my case. The max width the cooler can be is roughly 10cm so unless the 10cm is the width it can't fit. Thank you for the other suggestion as well.
[/quotemsg]
Good Speculation, you might find the coolers dimensions on their site? Ram wont be a problem as it is low profile. Also how far away is the case panel to the top of your current CPU? Those considerations e.g.[/quotemsg]
4cm away from the bottom of the power supply. The photo is a little misleading. The RAM (I think, is the ram the vertical circuit boards to the right of the CPU cooler?) goes halfway up the heatsink and is under 1cm away from the heatsink. The black components with the kinda peace sign on them are 2-3cm away from the cooler.
Yeah, or even the Noctua NH-U14S if it fits.
Thanks for all your replies but I've been told that Dell doesn't use the standard backplate, which is defined by the Intel specifications. Notcua have told me that none of there coolers will fit without modifications to the mounting system. How can I fit a new CPU cooler then?
