Cpu cooler radiator fans , auto , or full speed?
Lew201
71
Hello , I have bought a coolermaster seidon 120v cooler , I have 1 fan on each side in a push pull config , I have quiet fans , so I was wondering for better temps should I leave them on auto , or run them at 100% they are plugged into motherboard
If I should put them on 100% would I do this through bios or software
Many thanks
those temps are normal for air. if you want to reduce them you need to get water cooling.
I have got water cooling , a coolermaster 120v, with fans on each side of radiator
sorry, got confuse with the CoolerMaster Evo for a second. but yeah, your temps are pretty much good. 30C idle is really good, remember GTA V is an intense game so it will create heat!
Ok sweet , and also on auto if the rad fans need to go full speed they will do it auto won't they ?, because if I remember correctly when looking at the fan speeds underload they still weren't running full speed
they should run at full when the system needs them. but you can always manage that by using a software base solution, such as, SpeedFan
Ok , thanks you have been a huge help , I will leave it on auto , and see if I can get them to run at 100% when they need too
