L Lee_4_ Reputable Nov 30, 2015 2 0 4,510 Nov 30, 2015 #1 NZXT Phantom 410 CASE MSI BAZOOKA B150M Skylake Micro ATX i7 6700k 24GB Ram GTX 980 budget is £20 - £50 Thank you, any advice will be most appreciated.
Solution daddysl0th Nov 30, 2015 https://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2 Reliable,Cheap and one of the most standard cpu cooler https://uk.pcpartpicker.com/part/antec-cpu-cooler-kuhlerh2o650 Apparently really good but I would research more
daddysl0th Reputable Nov 30, 2015 27 0 4,540 Nov 30, 2015 Solution #2 https://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2 Reliable,Cheap and one of the most standard cpu cooler https://uk.pcpartpicker.com/part/antec-cpu-cooler-kuhlerh2o650 Apparently really good but I would research more Upvote 1 Downvote Solution
L Lee_4_ Reputable Nov 30, 2015 2 0 4,510 Nov 30, 2015 #3 daddysl0th : https://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2 Reliable,Cheap and one of the most standard cpu cooler https://uk.pcpartpicker.com/part/antec-cpu-cooler-kuhlerh2o650 Apparently really good but I would research more Thank you, the Cooler master cooler is one i was actually contemplating getting, nice to get a second opinion, seems like an all rounder. Upvote 0 Downvote
daddysl0th Reputable Nov 30, 2015 27 0 4,540 Dec 1, 2015 #4 Lee_4_ : daddysl0th : https://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2 Reliable,Cheap and one of the most standard cpu cooler https://uk.pcpartpicker.com/part/antec-cpu-cooler-kuhlerh2o650 Apparently really good but I would research more Thank you, the Cooler master cooler is one i was actually contemplating getting, nice to get a second opinion, seems like an all rounder. Happy to Help Upvote 1 Downvote
Alex Dorades Reputable Mar 28, 2015 195 2 4,710 Dec 1, 2015 #5 CPU Coller: Cooler Master Nepton 140XL ★★★★★ ($79.99 @ NewEgg) Very fast, quiet and cold. Only few seconds from full load to freeze down to idle. Upvote 1 Downvote
