Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Hi,
grylion <grylion@btinternet.com> wrote:
#Hi All,
#Building new system
Cool.
#Antec SLK3700BQE
#Asus P4C800 de luxe
#3.0GHz P4
#3HDDs
#CD-RW + possible DVD-RW
#two sticks 512mb Crucial memory
#No frills graphics card(fx5700)
5700 is nothing to sneeze at, especially if you already own it. But, I
wouldn't buy it at this point, the 6600 is a better choice, or 6600GT if
you can afford it.
In the same vein, unless I already owned the S478 MB and/or CPU, I
wouldn't go Socket 478. If I were buying Intel right now both I would
definitely go Socket T a.k.a. 775. The CPU price is actually a little
cheaper, and has a brighter future.
# Can anyone recommend a h/sink/cooler for the cpu and choice of 120m/m case
#fan/s
#I will not be overclocking.
If you are not into overclocking, you can "go quiet" and get an Arctic
Cooling ACSS4U Silencer 4 Ultra which has a variable-speed fan with its
own thermister. Unlike other thermister fans it is really variable-speed
not just two-speed. The Ultra TCL model has a clear fan with blue LED's
if you are into that.
I also have the heatsink the other poster recommended, the Cooler Master
Aero 4 Lite. It is a great cooler for overclockers, but is big and can
make a lot of noise when turned up. Being manually controlled you can
turn it down until it is reasonably quiet, but because it is manually
controlled you are dependent on some kind of temperature monitor to tell
you if you need to turn it up or are allowed to turn it down.
The Aero 4 Lite is pretty "cool", though, to leave 2 hours of heavy duty
gaming and find the CPU at 39C, and the speed control is only at 80%!
Ken.
Mail: kmarsh at charm dot net | Just say "no" to liars SCO and Soyo
WWW:
http://www.charm.net/~kmarsh | Return services to local CIS offices!
