Question Cpu Cooler Replacement Help
ColdStew
16
So i need a new cooler for my AMD FX 4300 processer and just need help with a recommendation. I think its a 70mm fan and i was wondering what one i should get to replace? It attaches via 2 clips and its a AM3+ 942 pin socket. Motherbaord is 760GM-P23(FX) MS- 7641. It has a bracket to connect the current heatsink and cooler with 2 dips. Its a 95 TDP. The heatsink sits face down on it and not vertically.
I bought an Antec A30 fan and it doesnt fit. The motherboard bracket is square and the one with the fan is a circle. what fans and heatsinks work with a 760GM-P23(FX) (MS-7641) motherboard AND Socket type AM3+ (942)?
