Motherboard msi h61ma-e35 and cooler raijntek juno xWhat motherboard do you have?
What cooler do you have?
No you can't connect RGB and fan motor to same header. IT needs RGB 4 pin header which your MB doesn't have. Only way would be to get an RGB controller.Cpu cooler i ordered has 2 cables, one for fan to work 2nd for rgb. Where do i connect the rgb on? I bought fan solitter, can i out the rgb in there?
But if i connected the cpu cable to the cpu socket to then the rgb lighted up, splitter i bought has 4 pin thereNo you can't connect RGB and fan motor to same header. IT needs RGB 4 pin header which your MB doesn't have. Only way would be to get an RGB controller.
Pins on fan motors and on RGB lights do different things so you can't interchange themBut if i connected the cpu cable to the cpu socket to then the rgb lighted up, splitter i bought has 4 pin there
Only one coleor at the time. an that's not RGB.Question is how did the rgb light up then?
