Hi!
I bought a very cheap cooler for an Duron 1600 Mhz today and although the seller told me that it only works with SPU speed less than 866 Mhz, I still thought that it is OK as it looks just like the cooler in an another Duron 1600 Mhz system that I have ( very small, everything). But now it tuens out that maybe there is something that prevent the system from functioning. In booting, the cooler just run for about half second and there is a Ding sound and it stop. I ahve to switch off the power again to be able to start.
If there is a limit on the CPU speed on cooler, is there anything to disable it as I think the fan size should be enough for the CPU.
Thanks
Thanks
