Firstly, black friday deals were pretty sweet, snagged the Sandisk Ultra ii ssd 480 gb ssd(never had an ssd before) for 95 bucks and best buy had half off everything logitech so I got a g710 for just 50 bucks.
But I have a 4790k and when finals week is over I'm planning on doing a little overclocking, nothing crazy, and I ordered a Hyper 212 Evo for it since the stock seems pretty crappy. I also ordered two Cougar case fans, hydraulic bearing, they were 11 bucks a piece including the rebate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553012&cm_re=cougar_blue_led-_-35-553-012-_-Product
They don't seem as cheapo as other fans for 10 bucks and 5 star reviews.
What I really want to know is what I should do with my case fans. This is my first build and my s31 urban case has two fans in it already, one 120mm in the rear for exhaust, and another in the front for intake.
There are places for fans on the bottom as intake, another in the front as intake and the top as exhaust. What would be a good setup? Should I use one of the fans as my cpu fan on top of the 212 evo heatsink and just run 3 case fans? Or should I run 4 case fans and leave the 212 evo as is.
Also, would I need a fan controller or just plug them into the motherboard like the ones included in the case. I don't know much about fan setup yet, and realize that cooling is pretty important. I don't have much going on in my rig but I feel like its something I should learn about because I get the feeling that I'm just going to keep buying parts and case management and cooling will be that much more important.
