Hello everybody,
I just had some really big problems with CPU cooling and I think my Corsair H60 is failing. Last weekend I had problems that it stopped cooling. My temperature was going to 70c only just checking at BIOS. Fans working fine but it felt like pump didn't worked. Everything is plugged in as it should be and it was working fine for like 2 years with no overheating problems. What I was able to find out if I place H60 tubes higher it's start working but it drops down a bit it works very slow or it stops. Even now I had my temp going over 60c and it dropped down as I just lifted tubes up. It runs now at 34c. It sound very good but as I understand my cooler is going to die anytime. What would you recommend me? Should I buy another H60 or maybe you would recommend me something better? I was very satisfied with cooling and I haven't tried any overclocking but I might look at as I think it should be possible to get more with no damage. My cpu is amd phenom ii x6 1090t. As well I have crossfire amd radeon HD 7870 graphics cards. I'm a bit new with PC's. Any advice would be grateful. If I missed any important information let me know. Ohh as well I have corsair cx 750m power supply.
Thank you
Thank you
