CPU Cooling fan for fx6300
im unable to dig up any info on the maximum cpu cooler height for the frontech army
only case dimensions , your case is 174mm (W) so i would go for a cooler 150mm or under to allow for room behind the mobo tray , standoffs and mobo
the coolermaster hyper TX3 evo stands 136mm tall and should fit in your case and is compatible with the fx 6300 and will perform better than your stock cooler
http://www.theitdepot.com/search.html?keywords=hyper+tx3&searchcategory=0&Search=
If you are just using the cpu for light usage then the stock cooler works (with a lot of noise if i may add). But if you are gaming or doing othr cpu intensive work the aftermarket cooling is always better (cooler , quieter)
http://www.flipkart.com/cooler-master-hyper-tx3-evo/p/itmd5xzprhxvefrj?pid=COLD5XZPV75JZAEZ&icmpid=reco_pp_hSame_cooler_1
http://www.flipkart.com/deepcool-iceedge-400fs-cooler/p/itmduu8xdxaxsmea?pid=COLDUU8X5NHUEYJG&otracker=from-search&srno=t_1&query=iceedge+400&ref=ddc44833-5b47-426a-bd18-f340ef1e9ebb
Won't the stock cooler be ok for games like BF 4 and Crysis 3?
I haven't bought fx6300 yet. So how will i know if it will hit above 70 C at stock cooler while playing crysis 3 or any other intensive game?
I live in Bhuj, Gujarat, India. The place is pretty hot but at night temperature cools down.
I would really recommend a cpu cooler then. Winter is coming in a few months but it is still a long way to go. As you said it gets cool at night then maybe limit yourself to night gaming till winters and then ride out the winter months with the stock cooler(and also hold off over clocking ) and then when you have enough cash (a little under 2000 rs) THEN you could get a good cooler because coolers under 1000 rs will not be able to keep the cpu cool in the hot summer months ( if you over clock then it will be an even bigger problem).
I think about 1500 - 1700 rs would get you a good cooler. And um.... one more thing I have a hyper tx3 and it cost me about 1600rs from the market.
The tx3's price in flipkart is 2000rs(price may be lower on other sites) sooo.... your decision if want to get it ftom the market or get it from the net. Good luck
If you haven't noticed (rim shot) I'm Indian too and I currently live in delhi.
