CPU Cooling Fan Questions
jkalas83
14
I was wondering if this cooler will fit on my mobo/cpu setup. Thank you for your time.
AMD Phenom II X4 955
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
This is the cooler I want to use
Xigmatek Intel Core i7 compatible THOR'S HAMMER HDT-S126384 CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233032
I know this is probably a stupid question to most people, but after searching through neweggs sight I just wanted some help. I could only find one fan on thier that said it was for am3 socket, and I just want to make sure everything is compatible before I buy it.
PS I have a huge Full tower care so space is not a issue.
