V VitaminB2014 Reputable Feb 15, 2014 46 0 4,530 Nov 17, 2017 #1 cpu cooling fan stops when inserting cpu......help cpu is new........pins straight......heats up wery quik...help
Barty1884 Retired Moderator Apr 16, 2015 22,250 1,350 108,740 Nov 17, 2017 #2 Your cooling fan shouldn't be running when you insert the CPU, everything should be off?? If the cooler isn't working with a new CPU, have you reconnected the fan(s) to the appropriate CPU_Fan headers on the motherboard? Upvote 0 Downvote
V VitaminB2014 Reputable Feb 15, 2014 46 0 4,530 Nov 17, 2017 #3 cpu fan fine without cpu in,u insertin cpu it stops,feels like trip Upvote 0 Downvote
