CPU Cooling for Ryzen 1700X
Joe0504
56
So I ordered all the components for my new build expect for the CPU Cooler.
It's out of stock
The Corsair Hydro Series H110i
So I was looking for other solutions, that will work without needing an AM4 bracket. Because this is also says 1-2 weeks from Corsair.
So I was looking at an Air Cooler by Noctua, NH-D15 SE-AM4
https://www.newegg.com/Product/Product.aspx?Item=9SIAADY5BC1607
It's also out of stock from NewEgg, but I can get it from Amazon.
Here is the system I'm building and everything I've purchased, minus the CPU Cooler.
Should I wait a few days for the Corsair H110i, or should I go ahead and purchase the Air Cooler by Noctua, NH-D15 SE-AM4
PCPartPicker part list: https://pcpartpicker.com/list/ZrGTD8
Price breakdown by merchant: https://pcpartpicker.com/list/ZrGTD8/by_merchant/
CPU: AMD RYZEN 7 1700X 3.4GHz 8-Core Processor ($399.99 @ B&H)
CPU Cooler: Corsair H110i 113.0 CFM Liquid CPU Cooler ($124.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory ($111.99 @ Best Buy)
Storage: Samsung 960 Evo 250GB M.2-2280 Solid State Drive ($129.99 @ B&H)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($177.89 @ OutletPC)
Storage: Seagate FireCuda 1TB 3.5" 7200RPM Hybrid Internal Hard Drive ($78.88 @ OutletPC)
Case: Corsair 750D Airflow Edition ATX Full Tower Case ($139.99 @ Newegg)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($111.98 @ Newegg)
Other: MSI GeForce GTX 1080 DirectX 12 GTX 1080 DUKE 8G OC 8GB 256-Bit GDDR5X PCI Express 3.0 x16 HDCP Ready SLI Support Video Cards ($504.98 @ Newegg)
Other: MSI B350 TOMAHAWK AM4 AMD B350 SATA 6Gb/s HDMI ATX Motherboards - AMD ($111.98 @ Newegg)
Total: $1892.66
Generated by PCPartPicker 2017-03-08 09:43 EST-0500
Thanks
Joe
The Noc is by far the better cooler as the H100i leaves the CPU 3C hotter while being 12 times as loud. If ya want water, nothing will be as quiet as the Noc but at least the Swiftech H240 X2 destroys the H100i temp wise by almost 10C and to get that close the H100i has to be more than 4 times as loud. See 30:28 mark
https://www.youtube.com/watch?v=PYKdKVxbnp8
At 55% CPU load, I'd want to leave the room w/ the H100i at 55% CPU load
https://www.youtube.com/watch?v=cTf0Vq1j4Ec
In addition, the H240-X2 contains a real water pump capable of over 1 gpm,. while the H100i manages only 1/1th of that which allows you to ass other items to the loop....say by water cooling your GFX card. It has a reservoir, it has a copper / brass radiator...
I would recommend the Noctua, providing your case is quite a wide one (Not too sure on the 750D). It will come fairly close to the window though. I have one and it is very quiet and remains very cool, even blowing what seems to be cool air from the rear and top of my case.
If you care for aesthetics just know that the Noctua blocks the majority of the motherboard above the GPU so if you like to look at your pc then i would recommend a more clean looking fan.
However i have the D14 that came before it and i can say it is certainly a beast.
The Noctua D15's tend to perform just as well as the H110i does, overclocking wouldn't be an issue.
In addition, the H240-X2 contains a real water pump capable of over 1 gpm,. while the H100i manages only 1/1th of that which allows you to ass other items to the loop....say by water cooling your GFX card. It has a reservoir, it has a copper / brass radiator so it does not create a galvanic corrosion cell within the loop.
https://martinsliquidlab.wordpress.com/2012/01/24/corrosion-explored/
With MSI already selected for the build, if you choose the Swiftech, I'd consider the EK Seahawk 1080 version. ... though I'd wait a bit and, with the impending release of the 1080 Ti, 1080 prices will continue to tank.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814127952
