Hi,
I currently have a Ryzen 5 3600 with the stock cooler on it currently. I am looking to upgrade the stock cooler.
However, I have a small problem. I can't decide if I should get an air or liquid cooler.
The problem with the liquid cooler is that I can't put it on the top of my case as according to Corsair pictures I can only put 2 fans on top. If I were to go liquid I would have to put the liquid cooler fans at the front which will then blow in hot air and 2 fans on top which will have to be exhaust so dust won't get in (I believe)
My specs are:
Motherboard: ROG Strix B450-F Gaming II
RAM: Cruical Ballistix 3600mhz CL16
GPU: Gigabyte RTX 2060
Fans: Deep cool RF120 3in1, 120mm
CPU: Ryzen 5 3600
Case: Corsair Spec-5
I may look into doing a overclock along with my GPU.
Thanks for the help.
My specs are:
CPU: Ryzen 5 3600
