Question Cpu cooling problem: 8350
mcintda
7
Hy everyone, I'd appreciate your help..
My old motherboard blew. Machine was completely dead: no screen, no beeps, only ancillary fans. It was an AM3+ armed with an AMD FX-8120. MB: Gigabyte GA-970-DSP3, ver. 1.1. Also, due to some fiddling I managed to blow the CPU too: at first during testing it would get nice & hot, then later it was cold. I know... smart. But I was grounded..
Anyway, I decided to swallow my pride and keep it simple: no big upgrade, just minimal $$$ to replace what was broke.
So I bought a new MB, identical, but v.2.1 was all that was avail. Same exact specs, looks the same. The different versions were probably nothing more than a BIOS upgrade - it is a 7yo mobo, after all. The 8120 I replaced with an 8350, also careful to stick with AM3+.
Problem: both the stock fan and my old Thermaltake cooler from the older (same model) motherboard will not fit! I have no way to cool the CPU to test everything.
Q: Is there a fan mount kit / other fan you can recommend so I can use this mobo / cpu combo?
Sadlah
70
7
If you have the old motherboard still, you could unscrew the CPU Cooler locking brackets and attach them to the new motherboard, that's one way i could think of, if it's am3+ though, they should fit.
Similar threads
