I have a P4C 3.0ghz that is not overclocked, operating @ 3007mhz. I just installed a Zalman CNPS7000A-All copper and for some reason when I look at my idle temps AsusProbe says it is @ 36C. Now I have a Thermaltake Xaser III case and the front temp monitor will fluxuate from 30-37 at idle. Prime95 torture tests get the cpu cooking up to 50C max at full load in asus probe. My temperature monitor reads about 60C. I'm unsure of why I'm getting conflicting temperature readings, because sometimes the asus probe temp is higher, and sometimes the temp monitor is higher, and sometimes they are the same.
I have 2 80mm fans placed in from of my mb and cpu. The top fan is placed directly in front of the heatsink. The air blows TOWARDS the heatsink. I also have 2 80mm fans behind the case that suck air out.
My question is, do you think I would get cooler and more consistent temperature readings if i turned my side fans around so it SUCKED air away from my new heatsink? Or is it wiser to just keep it as is and have it blowing on the heatsink?
P4C 3.0ghz
Asus P4C800E-D
GeForceFX 5900 Ultra 256MB
2x512 MB corsair dual channel pc3200
200GB WDJB HDD
Nothing OC'd
P4C 3.0ghz
Asus P4C800E-D
200GB WDJB HDD
Nothing OC'd
