CPU Cooling problems
bens201201
I have a I5 7600K with a Cryorig C7 with 2 1 front and back chassis fans and one facing downwards in my case and for some reason when i play games like Ark survival and BDO with low settings I'm sitting at 70C+, And I'm not sure why It's around 20C in my room because I live in Australia and its summer I cleaned out my fans/case and its still the same just wondering if anyone has any idea why. Also Would I be able to plug a normal 120MM case fan into the PWM CFG and do you think if so it would have any effect my GPU barely even hits 60C.
I also have GTX 1070, I always had FPS problems before getting a new PC now I have CPU temp problems.
at stock yeah. overclocking changes things dramatically.
overclockers have taken to de-lidding the chips to address the issue. removing the heat spreader, cleaning away the thermal paste and applying a better thermal compound
Cheers
