cpu cooling question ?
Liam230
98
i put in a new cooler (CoolerMaster Hyper 212X CPU Cooler) and all goes well installed it put everything back to together and you can wiggle the cooler just a abit have i not installed it properly? i screwed it down does it need to wiggle a little for the thermal paste? im not to sure im a bit worried
ok never had a cooler like this like i put a dab in the middle of the cpu and let the heat sink spread it out is that right?
yes i watched a video installing it and i read the instructions the four screws to hold it in place i screwed it all the way just a little worried never done something like this before
i started up the pc on bios where you can mointer the temps of everything and left it for 6 hours and come back and was the same temp i left it which was 43C celsius
