[SOLVED] CPU Core Temps & PC Makes Weird Noise on Startup
Mar 11, 2022
I haven't been concerned about CPU temps until recently when I started hearing a weird noise come from my PC on startups. It will last bout 3 seconds then go away. Very recently my temps sky rocketed to 100c and I couldn't get them to come down. I opened my case and felt the screws were slightly loose on my CPU cooler and so I tightened them. This seemed to help as well as blowing out dust, but the idle temp still seems high to me. I figured I would come on here and post it and see if you guys have any suggestions on what I should do.
CORE #0 | Min 53c | Max 94c
CORE #1 | Min 54c | Max 100c
CORE #2 | Min 52c | Max 96c
CORE #3 | Min 50c | Max 97c
CORE #4 | Min 51c | Max 94c
CORE #5 | Min 49c | Max 95c
MSI Mag Coreliquid 240R
View: https://youtu.be/9U_5aGf0G9Q?t=1250
Get it replaced.
Mar 11, 2022
CPU: Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz (No Overclock)
CPU Cooler: MSI Mag Coreliquid 240R - AIO (Installed 2/6/2021)
Motherboard: MSI Z490-A Pro (Socket 1200)
Power Supply: Corsair CX Series CX750M 750W 80 Plus Bronze (Installed 2/6/2021)
Chassis: NZXT H510 Compact ATX Mid-Tower Case w/ Tempered Glass
Phaaze88
Ambassador
Get it replaced.
Reactions: uWebb429
Just went to their recall page and put in the serial number and it said mine didn't qualify for the swap program....guess I'm buying a new one yayyyy mee
EDIT: Any suggestions on coolers? I'll go out tomorrow and hopefully pick one up and replace the thermal paste and stuff
