Problem: After pressing power, RGB on motherboard and RAM sticks comes on but no fans and nothing shows up on monitors. The CPU debug light on the motherboard is sold red.
Attempted solutions and mixed results:
-Reseated the GPU and checked all connections. No change to the situation.
-Reseated the CPU after checking pins, etc. Computer fully powered on as if everything was normal. No more CPU debug light. I spent an hour letting the computer run and even played some games. All temperatures for components read as normal. After turning the computer off and trying to power on again, the original problem returned. I assess that the CPU reseating was not the main source of the problem.
-Reseated all RAM sticks. Computer fully powered on as if everything was normal. No more CPU debug light. I spent an hour letting the computer run and even played some games. All temperatures for components read as normal. After turning the computer off and trying to power on again, the original problem returned.
-Reset CMOS by removing the battery and putting it back in after waiting for a bit. Symptoms of the original problem stayed the same.
Not sure what to do now since all the reseating procedures seam to fix the problem once and then after turning the computer off all the problems return.
Below are the basic specs:
MOBO: MSI Z270 Pro Carbon
CPU: i7 7700k
RAM: DDR4 8GB x 3
SSD: Samsung 500GB
GPU: GTX 1080ti
PSU: Seasonic GSeries Gold 750W
CPU: i7 7700k
RAM: DDR4 8GB x 3
SSD: Samsung 500GB
GPU: GTX 1080ti
