Hello there,
I recently completed a build featuring the parts listed at the bottom of this post. I started off with my old GTX 1080 for swapping out the CPU/RAM/Mobo. I ran into the same issue that I am facing now where my PC failed to boot up with CPU/DRAM error lights. I was able to resolve it but I do not remember exactly how. I believe I had tried:
However, that leads me to this point. I had replaced the 1080 with the 7900 XT when it arrived, and had no issues. After running tests and benchmarks on the 7900 XT, I then ran the DDU uninstaller, shutdown, disconnected power, and swapped for the 4070 Ti. When I attempted to start the PC on again, I was met with the same CPU/DRAM issue. This has left me utterly befuddled as I did not make any tweaks to any other parts. I did my best to ensure I was grounded and working in a static-free environment.
Given I had this same exact issue before, I tried running through the troubleshooting steps that I did previously. However, this has not worked unfortunately. In addition to those steps, I've done the following:
I think overall I might chalk up my previous success with getting the motherboard to boot as an anomaly as opposed to the norm. This is my first time dealing with such a complicated issue, though, so I would be happy to be proven wrong. Please let me know if you have any suggestions or ideas.
Thank you.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler
Motherboard: ASRock B650M Pro RS Micro ATX AM5 Motherboard
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
Storage: Samsung 850 Evo 500 GB 2.5" Solid State Drive
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Storage: Hitachi 7K2000 2 TB 3.5" 7200 RPM Internal Hard Drive
Video Card: PowerColor Hellhound Radeon RX 7900 XT 20 GB Video Card
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti 12 GB Video Card
Case: NZXT S340 ATX Mid Tower Case
Power Supply: Corsair RM650x 650 W 80+ Gold Certified Fully Modular ATX Power Supply
- BIOS Flashback (to update to the latest version, 3.01); I felt this was necessary regardless and so I did this first
- Reseating the CPU and checking for bent/broken pins (none)
- Adjusting the CPU cooler (some say AM5 has an issue with over-tightened coolers)
- A CMOS clear by shorting the two pins on the motherboard
- Reseating the RAM, trying different configurations. I eventually found success when using a single stick on the A2 slot.
- Removed the 4070 Ti. Tried booting with the iGPU, 7900 XT, and even my old 1080. No luck.
- BIOS Flashback to different versions (1.21, 2.02, 2.10)
- CMOS clear by removing the battery (3 seconds, then 10 minutes, then overnight)
- "Unboxing" the motherboard by setting it up with only the CPU. cooler, RAM on the motherboard box. I connected only the Mobo and CPU power cables, as well as the power button.
- Ensured my PSU cables were fully-in. I tested this on my old build and it had no errors.
- Waiting 5-10 mins after each boot in case there is a memory training issue (I feel that the CPU isn't being initialized at all, but I did this just to be safe)
Thank you.
![VvzhkKR.png](https://i.imgur.com/VvzhkKR.png)
