CPU fan 1500rpm when idle and while gaming
dejwiu
66
Hello,
So my cpu fan is running 1500rpm when idle and while gaming. Is it normal? If not what can i do?
It's stock intel fan and it's clean. Temperatures are ok. My motherboard is gigabyte b360m ds3h.
Auto option should be fine, and adjust on the fly, but you said yours was pegged at 1500 so maybe the auto feature is messed up. You could try a bios update to see if that helps, or as mentioned try the manual fan curve.
So the auto option isn't good?
