Cpu fan cable clip
PotatoDay
17
Hello,
My motherboard has clips to secure my cable so they cant disconnecting from my motherboard
But i have buyd a new CPU Cooler, and i want to disconnect my old one but is stuck in clip what can i do now?
My motherboard is a: Asus P9X79
Thank you
I have a a Asus P9X79-LE
And i cant add a photo but its like this: http://event.asus.com/2013/mb/pc_diy_guide/images/03_c05.jpg
I found it online if i take a picture it will look bad but is like this ^
Thank you for helping me
No you cant.
if you look good the cable has a small piece of plactic getting out of it and the motherboard to
Dude - they're like fan headers on every other motherboard on the planet. you need to firmly pull straight up. Tale care not to pull onthe wire, but on the plastic. Sometimes I have to use a needle-nose pliers since my fingers can't always get a good grip.
Not realy man maybe you cant see it on the picture but there is a clip You cant pull it out. with nothing
OK, I give up. Unfortunately few people read solved requests, so I will mark the solved answer you gave as "Unsolved" and maybe you can find someone else that will give you advice.
There are little clips on the 24-pin and CPU 4- or 8-pin headers connectors, and those you also just need to press with your fingers. I've never seen or heard of a motherboard or fan cables that have clips on their 3- or 4-pin headers or connectors.
Good luck in your quest.
