Question CPU fan color and rgb controlers?
Jeff_120
330
8
10,795
Yesterday I broke one pin of the 4 pins connector on my mobo, I used to connect the cpu fan rgb cable on it, now I have only 1 4pins connector left on my mobo on which I plugged my case fan rgb cable.
If I get an rgb fans combo that come with a hub, can I plug the cpu fan rgb on it if it has extra 4pins connectors?
I will then add one or 2 rgb fans on my case along the actual one and cpu fan.
The Aerocool Rev Rgb is good for that task?
