I am going to doing my first system build for myself *stepping away from the pre built* and iam either going to get the E/Q6600. But since i dont plan on doing any form of OC there really wont be too much need for a water cooling system just yet. So my question is which fan do you think would be best for thes processors. the ones ive been eyeballin is the ARCTIC COOLING Freezer 7 Pro 92mm, ZALMAN 9500A 92mm 2 Ball CPU Cooler, and the VIGOR GAMING CLT-M2I 92mm Thermal Electric CPU Cooler *aka Monsoon*.
if there is anyone out there that has used these fans, or has another one to recommend it would be great. Also i dont care about noise.
Thanks
Thanks
