Hi again, so i got at this brand model pc (hp 600 g2 mt lga 1151 6th gen ddr4 model) whitout cpu and ram, yesterday i buy an i5 6500 & 8gb ddr4 (lenovo 2666mhz), when i put into the pc and try to turn on, all turns on exceptly the cpu fan, the monitor does not display anything, tried with dp-dvi cable cuz i5 6500 does not allow vga (my monitor has vga/dvi output), whats your opinion, i think if i change the ram module to Crucial DDR4 8Gb 2666Mhz its gonna work, but maybe the processor is broken or something, did i need try to change the ram module? how i can check if my ram/cpu/fan its broken? or i need to send to repair/check
artic mx-4 as thermal paste so thats not the problem
how i can put an photo here? no idea how to insert it, tried with imgur link (doesnt work)
