CPU Fan Error and Immediate Shutdown
Big1Jake
Commendable
Oct 2, 2016
I built a custom PC that I've used problem free for about 8 months. Two days ago ago it threw a CPU fan error. I have read other threads, but they've been unable to help. I think the BIOS minimum fan RPM might be the problem, but the computer shuts down before I can even get into the BIOS.
Specs:
Asus M5A99FX Pro/R2.0 motherboard
AMD FX-9590 CPU
Corsair H80i gt liquid cooling
Corsair CS750M psu
Relevant Notes:
System shuts off before I can get into BIOS
Local tech store said CPU was fine
Warning beeps indicate hardware failure
Tried replacing CPU (used a friends 8350; same result)
Tried replacing motherboard (bought and refunded same model; same result)
Tried putting a different fan on the main CPU fan header (yes the cooler was stI'll plugged in)
Have replaced thermal paste at each point
Tried one of the H80i's fans on the cpu fan header and the lead from the pump to another fan header like the cpu-opt. header?
What warning beeps? =frequency.
To be sure did the store test with another psu as well? It should be able to run this system,but who knows ..
Vic 40
Ambassador
