Hi all,
I'm at a loss here. I searched the forums and saw many others have this problem, but it's usually right after they install a new liquid cooling system or recently made hardware changes. I have a desktop with liquid cooling (purchased the desktop completely preassembled, I'm not much of a hardware-assembling guy). Things were running perfectly. I shut down and went out of town for the night, and upon returning home this evening, everytime I try to boot up my PC, I get the "CPU Fan Error!" and can't boot into Windows.
-iBUYPOWER Gaming Computer PC AM5204Ei
-i7-7700k
-GTX 1080Ti 11GB
-16GB DDR4 RAM
-liquid cooled
Now bare with me as I try to stumble through this (remember, I'm not a hardware guy, so lots of searching on this forum and still in need of help)... when booting into BIOS, it detects my CPU fan running at around 6000 RPM, and the AIO Pump running at about 1050 RPM, but the CPU temp steadily rises in BIOS... starting out around 55C or so and within a minute or two, creeps up to around 90+ (at which point I freak out and manually shut off the pc). I bought a can of compressed air and cleaned all of the fans and the rest of inside my case, but no luck. All the fans are running, and when I place my hand on the tubes (the ones that extend from the 'water block?' that covers the CPU on the motherboard), they feel cool to the touch - not ice cold, but definitely cool, and I think I feel a very slight vibration, so perhaps my liquid cooling system/pump are working correctly? But if that's the case, why would the CPU temp be rising so quickly?
Some other info... the PC was preassembled purchased new and worked fine the 13 months I've had it - I began getting the CPU Fan Error without doing ANY modifications whatsoever, just started happening today when booting up my pc. If I have it on for a couple minutes and reboot, then I also get an error saying the CPU temperature is too high. The water block is plugged into the 3 pin "CPU_FAN" slot on the motherboard, and there's also another red/yellow/black cable that's plugged into 'AIO_PUMP' on the motherboard and runs to the fan all the way at the back of the pc (which I'm assuming is the fan for the radiator?)... but in the photo, there's a white rectangular block extending from these cables that's hanging loosely not plugged into anything... should this be plugged into something? Also, if I'm understanding correctly, this liquid cooling system doesn't use a reservoir?
I've tried ensuring all the connections are secure (unplugging/plugging back in), dusting everything off with compressed air, even attempting to change BIOS settings to no avail. Of course, if I set CPU Fan to "ignore", I can boot up windows fine, but the CPU is quickly rising in temp the whole time so that's not solving the issue. Despite feeling the tubes cold once the pc is powered on, could the water pump be failing?
Sorry for the lengthy post, but I've searched and searched and can't find a solution for this sort of behavior happening right out of the blue, so I'm hoping someone can bare with my lack of technical jargon/knowledge and guide me through this. Thanks in advance!
-i7-7700k
-GTX 1080Ti 11GB
-16GB DDR4 RAM
-liquid cooled
