Cpu fan error message with cooler master hyper 212 plus
Yamanater
9
I just recently build my new desktop and I have been getting this error message on start up that says something like "CPU fan error press f1 to continue" I am quite new to building but as far as i can see my fan is still running (at about 590 to 600 rpm according to my bios) and it seems that it is doing and efficent enough job because it is keeping my computer at about 35-39 degrees celsius. Is there actually something wrong? I am planning on overclocking soon but was scared with my fan acting up. I felt like i may have put on a little too much thermal paste, could that possibly be it as well? Im not sure where to start here, is it okay to keep using it in the mean time as long as its not showing that my cpu is jumping up into the high 50s?
Yamanater
9
I am almost positive it is in the right header it says [CPU Fan] on it so i can't see going wrong there.I talked to a tech guy at my school who said maybe updating the BIOS would help. what do you think of that?
autumnColors
5
If this happens during POST, then your cpu fan has not come up to speed yet (still less than 600 rpm) when the rpm is checked. This happens more often if the computer is at room temperature. It shouldn't happen if you do a Restart. If it does, you may have a fan problem. If you have a higher capacity fan on an aftermarket heatsink/cpu fan, (larger diameter fan), then this error message can happen often.
Yamanater
9
Yeah this never does happen during post actually. Its fine after restart, I'm just kinda paranoid since its my first build :/
robertris2
162
Hey, just happened to be going through this problem, searched in Toms and this post came up.. The thing that worked for me was to lower the minimum cpu fan RPM in my bios. When the fan starts up "the one that came with the hyper 212" it starts near 550 RPM, my BIOS was set to have a minimum CPU fan RPM of 600. Changing it down to 500 did the job. I'll be replacing the bundled fan soon.
