Cpu fan error predator g3620 fan problem
BenjaminITHelp
Commendable
Mar 15, 2016
Okay i am currently using a acer predator G3620. So i was patching blade n soul but it havent finish then i off it. After that later when i on, the window screen will load after that it will turn to black screen then my razer keyboard n mouse won't light so i off the main switch then turn on again. I went into bios chg to default setting after that It then become the American megatrend. It then says that the cpu fan error after that if i click f1 to continue it will say "reboot or select boot device or insert boot media in selected boot device and press a key" i got a feeling that it isnt spoiled but is that i click something wrong. Does any1 know how to fix this? Please help me because i am poor and i have no money to repair
First off - you should never kill power to a computer when the harddrive is being accessed. It could actually destroy the drive. In your case, it does sound like the drive is damage.
Do you have a friend with a working pc that can test the drive in their pc for you?
