this is the message that I get from the PC to the at start and do not Boot (bios is update)
the fan is rotating at 500 rpm is in the bios is marked in red
is a 4-wire fan. I worked around the problem by BIOS on the fan speed of the CPU I set IGNORE. there will be problems? I must look for a 4-wire fan compatible with my mobo? thanks
SABERTOOTH X79 + 3820 + COOLER MASTER 212 EVO
