CPU Fan Error
Mr. Koaliti
108
Whenever I boot my computer I see a message at the bottom that says 'CPU Fan Error!'.
But when I open my case and boot my computer it seems to run fine. I also have had no problems with my CPU. should I just brush it off or should I be worried?
Thanks for the help!
My build: http://pcpartpicker.com/p/3xb3Y
I tried that and it is still giving me the message.
No, it is in the correct slot. I checked before putting it in. there are two slots for a CPU fan and I put it in the first slot. And since I have a sabertooth 990fx I have a UEFI, I can see that it is in a CPU slot.
Is there a way for me to take a screenshot on boot?
Sure, if you have a cellphone with a camera.
I am not sure how to add the screenshot to my answer, it is not working
As anhilated said, you'd need to take the picture with a camera, sorry for the confusion.
