CPU fan error
wsnyder0080
When I turned on my computer today I got the cpu fan error message press f1 to continue. Im running an asus z97a board with a nzxt kraken x62 aio. Launched into the bios and it's not detecting the cpu pump. Everything else is working normally including the cpu cooler fans. Furthermore the aio pump is not pumping because cpu temps shoot up to 80+ degrees while the fans spin up trying to cool it. I have plugged the pump into multiple fan headers that I know work as well as the dedicated cpu pump header and no change.
Yes it does I've checked the data cable and it's fine. I also put an old corsair h60 on it and it booted up fine temps are fine everything's detected normally
