CPU fan for asrock x370 taichi
Vcaz02
20
I just recently built a computer and I'm trying to find a CPU fan that is compatible with the asrock x370 motherboard and ryzen processor, I tried the coolermaster 212 evo and coolermaster hyper t4. Both weren't compatible, thanks.
Your board (I have the same one) has two black plastic mounting brackets built in. DO NOT remove them if you get a cooler with a clamp mechanism. I have two of these coolers...one in plated nickle that looks great on the board: https://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
Any cooler with the clamping bracket as shown in a pic above will work. You place the solidnon-moving end of the bracket over the black mounting bracket at the top of the board, then gently but firmly press the other end (the end that has some flex/movement in the clip) downward over the lower black mounting bracket. Press until the latch part clips on. Done.
Granted, I have installed my two Zalman's numerous times and some boards are...
https://www.reddit.com/r/Amd/comments/5y1xmx/am4_cpu_cooler_compatibility_list_for_the/
Its because it just uses the old clip style clamp to hold it down, the other parts are for other sockets, see pict below.
Granted, I have installed my two Zalman's numerous times and some boards are tighter than others, which means cursing and bleeding. The Taichi was 5 seconds. Easy.... with experience. But just go gently and firmly and you'll be fine.
