kamilstoch Honorable Feb 3, 2014 149 0 10,710 Mar 1, 2014 #1 Hi there I'm looking for a CPU fan for under £30 for the FX8320. Will be doing overclocking to about 4.4ghZ. The case I'm getting already has 4 pre-installed fans.
G Guest Guest Mar 1, 2014 #2 "CM Hyper 212 EVO is the perfect CPU HSF for that budget!" Although 4.4GHz may not be stable for long on a 30 peso budget.
kamilstoch Honorable Feb 3, 2014 149 0 10,710 Mar 1, 2014 #3 Thing is I'm not sure if it will fit my case. I've heard that it is really wide. My case is the Zalman Z9 Plus
