Cpu fan help
DonkeyFlem
32
i just built my pc about two weeks ago i am worried about my hyper 212 evo is 500-600 rpm enough and do you suggest any software to boost that.
Hi. Use something like HW Monitor to check your temps. As long as the temps are down, there is nothing to worry about. I suspect you are fine though.
