I Infoniali Reputable Apr 2, 2014 4 0 4,510 Apr 2, 2014 #1 I see four little holes on each corner, I assume the screws are there. What kind of screw driver is used to tighten? [/not a hardware guy]
sunder25 Distinguished Jan 22, 2014 1,607 1 20,365 Apr 2, 2014 #2 Will need more information. Intel cpu with stock cooler? Upvote 0 Downvote
sunder25 Distinguished Jan 22, 2014 1,607 1 20,365 Apr 2, 2014 #3 does it look like http://www.pcstats.com/articleimages/201206/install1155_hsf.jpg Upvote 0 Downvote
E Erman Yudhistira Reputable Feb 26, 2014 270 0 4,860 Apr 2, 2014 #4 what cooler do you have? maybe you can give us some pictures. Upvote 0 Downvote
I Infoniali Reputable Apr 2, 2014 4 0 4,510 Apr 2, 2014 #5 http://imgur.com/MUbqKn5 Upvote 0 Downvote
sunder25 Distinguished Jan 22, 2014 1,607 1 20,365 Apr 2, 2014 #6 Is the fan loose or the whole thing? Upvote 0 Downvote
I Infoniali Reputable Apr 2, 2014 4 0 4,510 Apr 2, 2014 #7 When I press down on one corner (left top) it stops for a while Upvote 0 Downvote
E Erman Yudhistira Reputable Feb 26, 2014 270 0 4,860 Apr 8, 2014 #8 you don't need screw driver. this cooler use plug and unplug methode. Upvote 0 Downvote
