Question cpu fan issue
Nov 22, 2024
14
while installing my cpu fan its fall into the ground then i saw that crack in it after i installed it theres no other damage than that one showing in the picture its been 4 days now since that happened
my question is can i use it until i have cash for a new cooler , i marked it as a red circle
thank you so much in advance
I would just keep using it, so long as the fan is spinning without hitting anything (as the other commenter said), and the crack is not open and letting air out the side/messing up the air flow. I have that cooler, that crack is only in the fan housing and is not structural to the cooler or the mount, that piece of plastic only funnels the air/holds the fan on the top, and it's not a heavy fan
if your worried, the outer plastic (part that says AMD) un-clips from the plastic ring that's cracked, you would have to un-mount the cooler, but you could take off that outer plastic, and put a strip of black insulation tape over the outside of the crack, or a bead of plastic glue, just to prevent the crack from spreading, but if your planning on replacing it at some point it's probably not worth bothering
And actually, if it's a wraith cooler which it looks like it is, I'd just replace it anyhow because all the wraith coolers suck unless you're using the much larger heatsink of the Wraith Prism on a low TDP part like the Ryzen 3 or lower TDP Ryzen 5 models. The Wraith Spire and Wraith Stealth are just not very good and you won't even know or understand how poorly they cool (Although, they DO get by, barely) until you use something better and see how it doesn't ramp up and down constantly as load changes occur.
I'd recommend this, which is not expensive, but cools exceptionally well for the price, depending on what CPU model you have. What are your full hardware specs?
PCPartPicker Part List
CPU Cooler: Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler ($17.89 @ Amazon)
Total: $17.89
Generated by PCPartPicker 2024-12-10 12:01 EST-0500
i dont think its spreading its been 5 days now and its the same i think the crack is just done and not spreading anymore
Total: $17.89
ryzen 5 3600 im planning to get new one after christmas i guess
i only have that version in my country
Thermalright Assassin King 120 SE ARGB CPU Air Cooler, AK120 SE ARB, 5 Heatpipes, TL-C12C-S PWM Quiet Fan CPU Cooler with S-FDB Bearing, for AMD AM4/AM5/Intel LGA1700/1150/1151/1200​
it should be fine
as long as its not catching or slack it should be ok.
would still replace it also cooler is fine above
https://www.amazon.co.uk/dp/B0D93TNVHC?tag=pcp0f-21&linkCode=ogi&th=1&psc=1
