My CPU Fan is sightly making weird loud noise. These are the not the problems:
-My CPU is not overheating. (According to the temperature.) (Not quite sure, I felt the heat from the outside, not sure it's OVERHEATING from the INSIDE.)
These are the problems:
-The fan sightly silence for a bit when I closed some of the applications that uses a lot of memories.
-The LED (Or something like that) (In front of the CPU) is blinking. Is that normal or what?
