cpu fan noise increasing
Heran
124
when i playing games like ETS 2 in high graphic settings,after few minutes later the cpu fan speed is increasing.Then the game also start to lag.should i use liquid cooling for the cpu?
Intel Core 2 Quad Q9550
MSI GTX N660 2GB
4GB RAM
Intel DG43NB Motherboard
any answer will be helpful.
thankyou
Heran
124
Im just using the default cpu cooler.there are no additional fans inside the casing
tc983x
125
16
you need additional fans.. atleast 1 exhaust, and if possible two intake fans. That will give you a positive pressure inside the case and keep out dust.
