CPU fan not working
MrKenda
22
Hello!
The cpu fan on my computer is not spinning. I have bought a new heatsink and also tried plugging it into the system fan header but it still doesn't work.
Wondering if anyone knows what it could be!
Thank you very much
did.... did you also buy a new fan??
Is it a new fan? Two possibilities, the CPU fan itself is broken (bad) or the motherboard is broken (unlikely, but worse). Try plug a system fan into the cpu fan slot and see if it spins. If so, your CPU fan is likely broken. Keep a heatsink on the CPU while running this test, we wouldn't want overheating.
Sorry, wrote it wrong!
Yeah I bought a new fan
Sorry yeah it was a new fan.
I tried the cpu fan in the system fan slot and it still didn't work.
Also, my system fans are a different type of connector (3 pin) will it still work?
