So I have the CM Hyper 212 EVO and I arranged it in a push/pull configuration. One fan (push) is a 4-pin PWM and the other fan (pull) is just a standard 3-pin. My motherboard only has one CPU fan header (using the 4-pin fan on it), so I was wondering if I could put the 3-pin fan into a system fan header, so it would always run at it's highest RPM. Is this okay to do?
