I just bought a Rosewill RCX-Z775-SL CPU cooling fan as I have a Pentium 4 660 3.6 lying around without a cooler. A normal intel cooler blows the air straight up from the mobo while this cooler blows the air at a 90 degree angle. Which way should I position the fan to blow the exhaust? Down towards the floor of the case, straight back towards the rear exhaust fan or towards the top of the case. Common sense tells me to blow it straight back into the case exhaust fan but will this cause too much or conflicting air pressure or will the negative air flow of the case rear exhaust fan expel most of the cpu exhaust being blown into it. Thanks
