I'm trying to quiet my cpu fan (be quiet shadow rock slim). I installed it with the fan facing up although I've realised that directly above it is the top exhaust fan so with both fans trying to pull in air this may be inefficient. I don't think the cpu fan will fit sideways (I have a zalman z9 case). Would it be better with the fan facing down toward the gpu? Is there some other better arrangement?
Thanks
Thanks
