Hello all, I have a 4790k at stock speed(turbo to 4.4Ghz)
Cooling it is a Phanteks PH-TC14
Today I ran my first Prime95, and ended up with a max temperature of 77
(Temperature peaked within 2 minutes, then stayed steady for the next 8 minutes before I ended the test)
But my CPU fan displayed as running at over 1600 RPM, when it is only rated at 1300.
However the CPU fan is actually two fans, connected with a Y adapter.
So my questions are:
1.Is my CPU fan being pushed wayyyy too hard by my MOBO?
2.Is my CPU fan just far outperforming the rating?
3.Is my system reporting an incorrect RPM?
4.Is the system reporting double what my RPMs actually are, because the voltage is doubled to run to two fans instead of one?
5.If number 4 is the case, then that should mean at the peak stress test, my fans were only running at about 60% power, which would leave quite a bit of room for overclocking, right?
(I don't really plan on overclocking yet, just want to have a good understanding of what's going on)
![temperature%20test_zps0clutij9.png](/proxy.php?image=http%3A%2F%2Fi82.photobucket.com%2Falbums%2Fj252%2Fjordan1794%2Ftemperature%2520test_zps0clutij9.png&hash=7bdbc165f3c6941c4c251fe3fae2579a)
