I have just bought a new motherboard (MSI S1150 ATX H97 GAMING 3 Motherboard) and everything works fine except the CPU fans wont listen to the BIOS settings. Smart fan is on and it doesn't seem to change the fan speed even though the temperature is around 30-40. Thanks in advance
Under the BIOS settings it is seen as CPU_FAN 2 whilst on a CPU monitoring system it says SYSTEMFAN
Here are the fan speeds:
http://imgur.com/LzuUoob
PC Specs:
GPU: Asus GTX 760
CPU: I7 4770K (Asetek Liquid cooling system)
Motherboard: MSI S1150 ATX H97 GAMING 3 Motherboard
RAM: 16gb DDR3
PC Specs:
GPU: Asus GTX 760
RAM: 16gb DDR3
