CPU Fan Running wayyy too fast.
rspec95
25
I got a FX 8350 with the Wraith Cooler and for some reason the cooler is running extremely loud on low loads.
On idle its on 2000RPM, Yes it is attached correctly and my temperatures are fine.
Make sure you have the CPU fan plugged into the correct 4 pin socket on the motherboard named 'CPU FAN"
I'm not sure what motherboard type you have, however you can go into the bios and change the RPM.
Tried all that.
Came up with a bit of an update, whenever my temp goes above 30 degrees my fan goes turbo to get it back down to 30. Not sure how to fix this, no option in my Bios for that. Im using a GA-78LMT-USB3 Rev6
