I bought a gigabyte ga-78lmt-usb3 rev 5.0 and amd fx 6300. When I plug CPU and cpu fan into place, then power it up the CPU fan doesn't spin. I plugged it into the case fan socket and it worked, I also tried another fan in the CPU fan socket and no luck. So I deduced that is is most likely the CPU fan socket which looks fine or the CPU is not being detected. This is brand new mobo, what could be the problem?
