Thanks for the translation, Sveraken. You have a good point there. OP may NOT have made the connections to mobo headers as instructed with the AIO system. In particular, if there is NO item plugged into the CPU_FAN header, that will certainly produce the error shown on the screen.
Darioslim, tell us exactly which maker and model number is your AIO system, so we can look at its inctructions. They all are a bit different, so there is no single way to plug things in that works for all AIO systems..
