Question CPU Fan speed increases to maximum while gaming
Jul 26, 2019
I have i5 4570 3.2 and 1060 6 GB and 16 GB DDR3 1600 mhz. My CPU fan increases to maximum after 2 mins of gaming no matter what Graphics Settings I use. FPS is above 60, CPU temp is about 60 while gaming, but CPU fan starts to increase to maximum for no reason. Too loud holy moly Anyone knows a reason?
alceryes
Assuming this is a new occurrence, have you checked all case fans to make sure they are functioning and cleaned all the dust monsters out?
Do you have any fan control software in place?
Have you checked the BIOS for fan curve settings?
It is summer in the northern hemisphere. If the ambient room temperature has gone up by a good amount it could be that you are just hitting the next fan curve threshold.
